kknd1928
Jan 08, 2022Initiate
A6210 drivers not work on Windows 11 - Cannot connect to 5G
Dear Support, Here is my equipment: Network Adapter: A6210 Router: TP-LINK XDR6080 Computer OS: Windows 11 The 5G of A6210 does not work on Windows 11. Before, on Windows 10, I installed ...
- Jan 08, 2022
Thanks, I have fixed this issue.
Before I update the setting, the Windows cannot found the SSID of 5G .
Now, I go to the Computer -> Device manager -> Network Adapter -> Right Click NETGEAR A6210 WiFi USB3.0 Adapter -> Attributes -> Advanced -> Channel Mode -> Change 2.4G+5G to 5G only.
I have contected to Wi-Fi 5 with 802.11ac once do above update, so this is maybe a Windows 11 bug?
Jan 08, 2022Guru - Experienced User
does the tp-link use a form of smart connect? Or combining the 2.4ghz and 5ghz bands?
If so, you can disable that so you can choose which band to connect it.
Smokemeone35
Feb 07, 2022Aspirant
