Reik1
May 12, 2019Aspirant
A6210 keeps disconnecting
Hello, I bought the A6210 WiFi USB adapter adapter some time ago (a couple of months) and at first I wasn't having any problems but soon after it keeps disconnecting from my computer. In a day someti...
Blanca_O
May 14, 2019NETGEAR Employee Retired
Hi Reik1
Welcome to NETGEAR Community!
May I know the operating system of your computer?
Was there any updates/changes on your computer prior the issue?
What happen if it disconnects? Do you need to unplug and replug the adapter? Or it will just reconnect to the network?
You may try performing the troubleshooting steps here: https://kb.netgear.com/23352/
Blanca
Community Team
- acristoMay 15, 2019Aspirant
Hi there, the same issue at my end.
I see many people reporting this issue but noone is willing to follow your suggestions. Let me work together with you to sort this out once and for all.
1. Router -> TP-LINK Archer C6 WIFI AC1200
I think it has latest drivers, but I'll double check. On the other hand, none of the other devices I use (couple of laptops or mobile phones) disconnect from the network. Only A6210 keeps unplugging - when it happens I hear it being unplugged... like I'd physically remove the connector out of USB 3.0 port. This could be potentialy USB 3.0 Power management feature.2. Latest drivers applied (1.0.0.39)
3. The guide is obsolete as there is no such option in the latest drivers. That could be OS thing as well. You're clearly using Windows 7 as an example while people are using Windows 10 for years now.
Extra options:
I've just forced 5Ghz only mode, USB 3.0 only mode in advanced settings.
In Windows10 Power Options, I've already had Wireles Adapter Setting, Power Saving Mode set to Maximum Performance - despite that the connection was dropped for me 10 minutes ago.
What I've changed in that section just now, is USB settings, USB selective suspend setting. It was set to Enabled and I've just switched that to Disabled state.
I'll observe if anything changed as a result of my actions. Definitely be back with the feedback. Please, don't mark this topic as resolved untill you hear back from me.
Went ahead to also disable NetgearSwitchUSB service. I guess this one is only working when you have the USB setting (in Device Manager / Wifi Properties / Advanced) set to Automatic anyway, so once I've set the setting to only be 3.0, the service wouldn't be doing anything anyway.
- Blanca_OMay 15, 2019NETGEAR Employee Retired
Hi acristo
Thank you for sharing all this information. I'll wait for your update.
How often does the connection drop?
Blanca
Community Team
Blanca_O It may happen couple times a day and the other day you wouldn't notice anything wrong. I guess it is down to how much I use my PC in given day. Let's say on average you will have 1 disconnect per day.
Reik1 I highly recommend you to follow what I've described around USB settings. Set it to 3.0 only for now (in device manager) or completely disable mentioned windows service. Both of these should have positive result when it comes to device plug/unplug scenario.
- Reik1May 15, 2019Aspirant
Hello,
My operating system is windows 10. There have been multipule updates to the OS since so I can't really pin it down. The device itself disconnects from the PC, Saying that it isnt recognized only for it to connect moments later. Sometimes I must remove it from the USB port and plug it in again for it to be recognized.
