Reik1
May 12, 2019Aspirant
A6210 keeps disconnecting
Hello, I bought the A6210 WiFi USB adapter adapter some time ago (a couple of months) and at first I wasn't having any problems but soon after it keeps disconnecting from my computer. In a day someti...
Blanca_O
May 14, 2019NETGEAR Employee Retired
Hi Reik1
Welcome to NETGEAR Community!
May I know the operating system of your computer?
Was there any updates/changes on your computer prior the issue?
What happen if it disconnects? Do you need to unplug and replug the adapter? Or it will just reconnect to the network?
You may try performing the troubleshooting steps here: https://kb.netgear.com/23352/
Blanca
Community Team
Reik1
May 15, 2019Aspirant
Hello,
My operating system is windows 10. There have been multipule updates to the OS since so I can't really pin it down. The device itself disconnects from the PC, Saying that it isnt recognized only for it to connect moments later. Sometimes I must remove it from the USB port and plug it in again for it to be recognized.
