flrebroker
Dec 10, 2019Aspirant
A6210 stuck on software 5.1.35.0
Using very latest Windows 10 version but problem occured in earlier versions. Driver is stuck on 5.1.35.0. I used to have MediaTek driver installed as well. When I look through the previous s/w ve...
flrebroker
Dec 11, 2019Aspirant
Meant to also say the reason I am trying to update driver is because I have been getting BSOD errors a lot recently. I have received bad pool caller and kmode exception not handled. I am thinking the A6210 driver could be the issue. Thanks.
- Blanca_ODec 17, 2019NETGEAR Employee Retired
Hi flrebroker
Are you still getting BSOD errors if you will disconnect the adapter? Please try cleaning the registry of the computer and see if this will resolve the issue.
Blanca
Community Team
