flrebroker
Dec 10, 2019Aspirant
A6210 stuck on software 5.1.35.0
Using very latest Windows 10 version but problem occured in earlier versions. Driver is stuck on 5.1.35.0. I used to have MediaTek driver installed as well. When I look through the previous s/w ve...
oraclewizard77
Apr 25, 2020Aspirant
I get device not detected when I try to update to a newer driver. Also Windows says I have the latest driver. Trying to upgrade to the stand alone driver 5.1.39 from 5.1.35.
The exe will not install the newest driver due to this issue. Is there any way to just get the driver file itself so I can do a manual install.
Or should I just consider this to be a **bleep**ty product that keeps disconnecting and order from a different company a newer ac usb Wifi adapter.
