daniel_rydell
May 29, 2019Aspirant
A6210 Wireless Adapter Keeps Uninstalling
So. I'm out of options, and I'm pretty much out of time. I have an A6210. I've never had any issues with it. All of the sudden, it's randomly losing its connection to my computer. Not the interne...
Blanca_O
May 29, 2019NETGEAR Employee Retired
Welcome to NETGEAR Community!
May I know if you already tried to uninstall and reinstall the driver? If not, please do so and install the latest driver 1.0.0.39 https://kb.netgear.com/000058840/A6210-Software-Version-1-0-0-39
Did you try connecting the adapter to a different USB port?
How often does the issue re-occur?
We suggest to do the following steps: Go to Control Panel > Hardware and Sounds > Power options > Change plan settings > USB Settings > USB selective suspend settings > set it to 'Disabled'
Blanca
Community Team
daniel_rydell
Have already done so, had the most up to date driver, still occurred.
Four different USB ports. Same problem.
Every few minutes. Only way to correct it is to restart the computer.
Did that last night, no difference made.
- Blanca_OMay 30, 2019NETGEAR Employee Retired
Our support team is looking into this issue and would like to work with you. Please check you inbox.
Blanca
Community Team
