Silverpoptart
Sep 18, 2016Aspirant
A6210 wont install or uninstall
Hello I purchased my netgear a6210 adapter in june and installed it in june with no problems at all using the disc. Yesterday I updated my computer and when i came back today and laucnhed the netgear...
Silverpoptart
Sep 26, 2016Aspirant
I got it to finally uninstall but now it isn't detected when I try to reinstall
XxDarkMarioxX
Remove the program do not install it and try the https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility-
This one might work for you! Because i got mine to work on windows 10 same device and its working perfect and not got the netgear drivers installed.
- SilverpoptartSep 26, 2016Aspirant
this might be a dumb question but what exactly do I do to set up the adapter If i download those drivers instead
