TrippyKYLE's avatar
TrippyKYLE
Follower
Jan 24, 2021
A6210/AC1200 Disconnects from WiFi while Streaming
I've had a consistent problem while streaming games on my AC1200/A6210 USB adapter. Everytime I stream it'll be great at first, everything is working I am connected to the internet, then boom 30 minutes later I am disconnected from the WiFi. This only happens when I stream, other than that I have no problems with it. I have the latest drivers for the adapter and my WiFi is pretty great as well with an average 130 down. and 40 up. I change my driver settings in the advance tab to what other people recommend, but the issue is still there. I even stopped and disable the USB switch mode that occurs in the task manager service tab. I just want to know how to fix this problem, so I can go back enjoying streaming again without this problem occuring.
-Thank You
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Any other clues? That provides not much to go on.
    Only you know what "other people recommend" and what you changed. Did that include USB sleep mode?
