Lazor_Marx
Jul 25, 2020Aspirant
A700 nighthawk drivers
Hi Guys, My PC does not have a CD ROM reader to read the disk for the drivers installation... was wondering if there is another way to install the drivers without the use of the CD ROM. (Ive tried ...
Lazor_Marx
this is what it says on the status: The drivers for this device are not installed. (Code 28
- michaelkenwardAug 01, 2020Guru - Experienced User
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware and drivers for your device. Download and install.
