Ahmads
Dec 13, 2019Aspirant
A7000 – Nighthawk AC1900 WiFi USB Adapter compatibility with WIndows Server 2016
Hi,
Is Nighthawk AC1900 WiFi USB Adapter (A7000 driver) compatible with Windows Server 2016? Is there a different driver that I can use as the A7000 does not work.
Thanks
- Tom444Apprentice
Buy another device, the A7000 will do your head in.
Drivers will give you a connection for a while, then just drop out for no reason.
The device is also rather deaf. Works fine without a pane of window glass infront of it. Put one infront of it and fails to connect.
- AhmadsAspirant
Thank you for the reply.
