BoomerLenny
May 10, 2020Tutor
a7000 and Mac OS Mojave
Has there been any timeline on a new driver to support Mojave and Catalina - 1.0.0.9 doesn not work. I saw in another pot that it was slated for 1Q 2020 - but I don't see anything am I missing it? ...
- Oct 05, 2020
Hi, All,
Please be informed that we already released A7000 driver that supports MacOS Catalina (version 10.15).
Here's the release notes and download link:
https://kb.netgear.com/000062424/A7000-Software-Version-1-0-0-13-Mac
Blanca
Community Team
Blanca_O
Jul 06, 2020NETGEAR Employee Retired
Hi BoomerLenny,
Welcome to NETGEAR Community!
This has been brought up already to engineers. We will provide update once new information will be available.
Blanca
Community Team
- BoomerLennyJul 21, 2020Tutor
Blanca -
Thanks for your reply.
This has been sitting with the "engineers" for over a year - if you're not going to do anything about it, just tell us and we'll move on - i'm about ready to invest in another system, but can hold off for a bit - moving to mesh as soon as this is resolved -
Lenny
- BoomerLennyAug 04, 2020Tutor
I have a workaround.
I was trying to update my old edimax ac1200 mini adapter when I accidentally installed it's driver when the A7000 was plugged in.
It worked, I'm using the A7000 on Mojave right now.
go to this page:
https://www.edimax.com/edimax/download/download/data/edimax/global/download/
box 1 home
box 2 wireless adapters
box 3 EW-7822UAC
box 4 Drivers
Get driver 1.0.3.6, ostensibly for Catalina (if this works for Catalina, let us all know), install, restart
I had to uninstall my old drivers first, so after I unzipped the file, I ran the uninstall first, just to be sure, restarted, then ran the install with the A7000 plugged in, and now the A7000 is working.
- Paul_in_EugeneAug 11, 2020Initiate
This workaround functions for my A7000 as well, and on Catalina . . . but why is it that, if a tiny outfit like Edimax can do it, and Chris111 on GitHub can do it, the "engineers" at NetGear seem out of their depth?
I specificaly boght this because the specs said "Mac OS X 10.8.3 or later" -- copied and pasted from the current product page at https://www.netgear.com/home/products/networking/wifi-adapters/A7000.aspx It is not right that this long after the release of Mojave (and now Catalina) they have yet to come up with a supported solution.
