BoomerLenny
May 10, 2020Tutor
a7000 and Mac OS Mojave
Has there been any timeline on a new driver to support Mojave and Catalina - 1.0.0.9 doesn not work. I saw in another pot that it was slated for 1Q 2020 - but I don't see anything am I missing it? ...
- Oct 05, 2020
Hi, All,
Please be informed that we already released A7000 driver that supports MacOS Catalina (version 10.15).
Here's the release notes and download link:
https://kb.netgear.com/000062424/A7000-Software-Version-1-0-0-13-Mac
Blanca
Community Team
BoomerLenny
Jul 21, 2020Tutor
Blanca -
Thanks for your reply.
This has been sitting with the "engineers" for over a year - if you're not going to do anything about it, just tell us and we'll move on - i'm about ready to invest in another system, but can hold off for a bit - moving to mesh as soon as this is resolved -
Lenny
BoomerLenny
Aug 04, 2020Tutor
I have a workaround.
I was trying to update my old edimax ac1200 mini adapter when I accidentally installed it's driver when the A7000 was plugged in.
It worked, I'm using the A7000 on Mojave right now.
go to this page:
https://www.edimax.com/edimax/download/download/data/edimax/global/download/
box 1 home
box 2 wireless adapters
box 3 EW-7822UAC
box 4 Drivers
Get driver 1.0.3.6, ostensibly for Catalina (if this works for Catalina, let us all know), install, restart
I had to uninstall my old drivers first, so after I unzipped the file, I ran the uninstall first, just to be sure, restarted, then ran the install with the A7000 plugged in, and now the A7000 is working.
- Paul_in_EugeneAug 11, 2020Initiate
This workaround functions for my A7000 as well, and on Catalina . . . but why is it that, if a tiny outfit like Edimax can do it, and Chris111 on GitHub can do it, the "engineers" at NetGear seem out of their depth?
I specificaly boght this because the specs said "Mac OS X 10.8.3 or later" -- copied and pasted from the current product page at https://www.netgear.com/home/products/networking/wifi-adapters/A7000.aspx It is not right that this long after the release of Mojave (and now Catalina) they have yet to come up with a supported solution.
- Blanca_OOct 05, 2020NETGEAR Employee Retired
Hi, All,
Blanca
Community Team
