BLEHG
May 31, 2023Aspirant
A7000 and macOS Monterey, Version 12.5
The drive software won't install and won't give any explanation beyond: "An error occurred during installation. The Installation failed. The Installer encountered an error that caused the installa...
schumaku
Jun 01, 2023Guru - Experienced User
Talking of https://kb.netgear.com/000062424/A7000-Software-Version-1-0-0-13-Mac or of what ever prehistorical drivers made available a decade ago with the product?
- BLEHGJun 02, 2023Aspirant
schumaku Of course I'm talking about version 1.0.0.13...
Why would I be trying to install a decade old driver? 🙄- michaelkenwardJun 02, 2023Guru - Experienced User
Does the Mac driver have the same option as Windows?
There you can choose between drivers or drivers with management software.
michaelkenward wrote:Does the Mac driver have the same option as Windows?
No, if I'm understanding correctly, it does not. There are very few options when trying to install the Netgear driver on a Mac. And there is no real management software. It's just basically a tray icon with a dropdown menu.
