miggity
Sep 08, 2020Aspirant
A7000 cant connect to 5g network
I just got this wifi adapter this new wifi adapter. I have spent nearly 6 hours connected to the 5g network and had a consistent 115 mbps download speed. All the sudden my internet was extremely slow...
miggity
Oct 05, 2020Aspirant
Now the adapter is randomly disconnecting and connecting back. It is making the sound when you unplug a usb device. I can also connect to 5g right now but a windows message pops up that has never in the past saying this network is unsecure because it uses an older security standard. It is also strange because I used to get 90-120 Mbps download being on the 5g network and now I am getting a max of like 30.
Oct 05, 2020Guru - Experienced User
Are you using this on windows or mac?
- miggityOct 05, 2020Aspirant
I have Windows 10
- plemansOct 05, 2020Guru - Experienced User
have you tried completely uninstalling the netgear utility and driver and then reinstalling the stand-alone driver version?
I only have the stand alone driver version because i read the other driver with the app gave people problems.
