Stomlin11
Mar 31, 2020Aspirant
A7000 Can't Connect WiFi
Hello all, I am currently having trouble connecting to a new router I installed. I had the stock Fios Gateway Router that came with my Fios internet and was successfully using the A7000 WiFi adap...
michaelkenward
Apr 01, 2020Guru - Experienced User
Stomlin11 wrote:
...with the A7000 I am able to connect to my phones hotspot, it is specifically my routers WiFi it cannot connect to.
Kind of suggests that it is the router's wifi that is the issue.
Not knowing what that is, it is anybody's guess.
Stomlin11
Apr 01, 2020Aspirant
Thank for your reply. Yeah im not sure what to think, every device in my home can connect to the new router except for the A7000 adapter and my work laptop. The new router is the g3100 from Verizon (WiFi 6) it is supposed to be backwards compatible and is on all other devices with the exception of my A7000 and work laptop.
- michaelkenwardApr 01, 2020Guru - Experienced User
What does Windows network troubleshooter say?
- Stomlin11Apr 01, 2020AspirantI ran it last night but had to revert back to my older router today for work. I cant remember exactly what it said except that its recommendations were steps i had already taken such as resetting the router. One step i didnt take due to distance was a wired connection between PC and router.
An off the wall one, maybe you need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
I am told that I am talking rubbish when I suggest that, but it has worked for some of us. Nothing lost if I am wrong.
