scoorat
May 17, 2020Follower
A7000 Causing Blue Screen on Windows 10
So I'm sure we're all well aware of the A7000's brilliant disconnection/reconnection usb switching issues. I was able to get past this problem by disabling the usb switching tool that gets installed ...
Algren
Sep 28, 2020Initiate
I also have this adapter and it will blue screen any PC I use it with. DMP file points to the driver crashing each time. It worked for a few months before and now it crashes the entire PC every 20 min or so.
