scoorat
May 17, 2020Follower
A7000 Causing Blue Screen on Windows 10
So I'm sure we're all well aware of the A7000's brilliant disconnection/reconnection usb switching issues. I was able to get past this problem by disabling the usb switching tool that gets installed ...
Blanca_O
May 24, 2020NETGEAR Employee Retired
Hi scoorat
Welcome to NETGEAR Community!
Does issue occur if adapter is connected to 2.4GHz network? 5GHz network? or both band?
What do you do if issue re-occur? Do you need to unplug and replug the adapter? Does restarting the computer temporarily fix the issue?
Please try to plug the adapter to different USB port.
Blanca
Community Team
Jason21Smith
Nov 12, 2020Initiate
I am having the same problem. My computer blue screens and says the Kernal Error... I am using 5Ghz and I have unplugged and replaced it multiple times. What happens is it blue screens then auto restarts your computer... then it is fine for a little bit but then blue screens again. I will try plugging it into a different port.
