shadowfax20
Jun 16, 2021Aspirant
A7000 Genie application does not start in WIN10
everything works fine except for this application; it does not start
- Jun 17, 2021
Thanks to Google, I just found this:
genie | Product | Support | NETGEAR
It works. But grab it while you can.
I have no idea what you mean by "change of MgH".
michaelkenward
Jun 17, 2021Guru - Experienced User
You refer to the "genie application". This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
- shadowfax20Jun 17, 2021Aspirant
I am using it for WIN10. It worked. I can connect, but I do not have access to the software of the WIFI adapter. I am clicking the icon and nothing. I also reinstall the software.
- michaelkenwardJun 17, 2021Guru - Experienced User
shadowfax20 wrote:
....I do not have access to the software of the WIFI adapter.
What software is that? What do you want to do with it?
the programme allowed to see the network structure and the change of MgH.: A7000_V1.0.0.15_Windows.
