xeerch
Aug 09, 2020Follower
A7000 "Link speed (Receive/Transmit): 54/1300 (Mbps)" on Windows 10
I was expecting a symmetric 1300/1300 Mbps link speeds with the A7000 since I also have an integrated WiFi Adapter Intel Dual Band Wireless-N 7260 which can connect at 300/300 Mbps, however I always ...
sthaus
Sep 28, 2020Aspirant
Hi all & Netgear Tech Support,
I recently has the same issue like 54/1300Mbs such people mentioned here .. since I upgrade to new computer
I also found that I have Intel Wireless AX on board as well in my mobo Gigabytes Vision D 550. But I disabled the mobo wireless adapter since its only support up to 866Mbs in 5G AC mode and my router is only AC router that support at 1766Mbs.
I only can suspect the Netgear's driver (outdate) since windows 10 v2004 release ? or firmware need to be upgraded ? or incompatible with 2nd wireless adapter such as Intel onboard. ?(but its weird then).
Is there any recomendation for fixing the problem ?
Steven from Au.
