elliottah
Feb 06, 2022Follower
A7000 Nighthawk AC1900 Genie no connect button?
I used this WiFi adapter for school, but stopped using it for two months as I did not need it anymore. It worked fine before, but now that I have started using it again, there is no "connect" button ...
michaelkenward
Feb 06, 2022Guru - Experienced User
elliottah wrote:
How am I supposed to input my login if I do not have the opportunity to do so?
We don't know what you are using to connect to the wifi.
If this is a Windows PC, then that is where to look for a "connect to the wifi" option.
Look for something that calls itself
Open Network & Internet Settings
If you are in Windows 10, there's a Notification button top/bottom right, with luck it will have a Network option.
Also look here:
Fix network connection issues in Windows 10
Essentially, it is down to the PC. The adapter just does what that tells it to do.
Maybe you also installed the Netgear genie for Winws at some stage. If so, look for that in your Windiows menus.
Manuals are also a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the Quick Start Guide.
