elliottah
Feb 06, 2022Follower
A7000 Nighthawk AC1900 Genie no connect button?
I used this WiFi adapter for school, but stopped using it for two months as I did not need it anymore. It worked fine before, but now that I have started using it again, there is no "connect" button ...
michaelkenward
Feb 07, 2022Guru - Experienced User
elliottah wrote:
How am I supposed to input my login if I do not have the opportunity to do so? I am probably missing something as I have not used it...
Try WPS.
