Saberstorm1000
Mar 07, 2020Aspirant
A7000 Nighthawk AC1900 wireless adapter turning itself off
Hello, I recently purchased an A7000 wireless adapter for my pc. Works great sometimes but after an hour or so it will randomly turn itself off and refuse to connect to my router. I have windows 10, ...
Mar 09, 2020Guru - Experienced User
Try doing a clean install of the driver. here's a video showing how.
Saberstorm1000
Mar 09, 2020Aspirant
- I have tried this and it will sometimes fix the issue an sometimes will not but even in the cases that it does fix the issue once I turn my computer off it has the same problem again. I forgot to mention this in the initial post but from time to time instead of just shutting itself off it will disconnect all my usb devices as well.
- plemansMar 09, 2020Guru - Experienced User
Is it disconnecting from the computer or is it just unable to connect to the wifi?
- Saberstorm1000Mar 14, 2020Aspirant
It is fully disconnecting from my computer and my computer cannot find the adapter for 30 seconds or so.
As of the most recent update to Windows 10 I also have terrible reception on this adapter and it will continuously drop connection to the WiFi as well as disconnect from my computer.
