ThePeskyDingo
Sep 06, 2020Aspirant
A7000 No Internet, secured
Just moved into a new home and got Comcast's xFi gateway for my internet. No issues connecting to the network on any of myt other devices and even am able to connect old usb WiFi adapters and get...
- Sep 10, 2020
ThePeskyDingo wrote:
It's when I click on the wireless icon in the lower right corner.
Is that the Windows network icon?
If so, that definitely suggests a Windows networking issue.
My first guess is that you may need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
michaelkenward
Sep 07, 2020Guru - Experienced User
No issues connecting to the network on any of myt other devices and even am able to connect old usb WiFi adapters and get my desktop online with them which leads to the issue being with the AC7000.
Likely to be a Windows networking issue.
Where do you see this message?
- ThePeskyDingoSep 09, 2020Aspirant
- michaelkenwardSep 10, 2020Guru - Experienced User
- Network Status
- Network Profile
- Private
- ThePeskyDingoSep 22, 2020Aspirant
This worked!
Thank you.
