ThePeskyDingo's avatar
Sep 06, 2020
A7000 No Internet, secured
Just moved into a new home and got Comcast's xFi gateway for my internet.   No issues connecting to the network on any of myt other devices and even am able to connect old usb WiFi adapters and get...
  • michaelkenward's avatar
    michaelkenward
    Sep 10, 2020
    ThePeskyDingo wrote:
    It's when I click on the wireless icon in the lower right corner.
    Is that the Windows network icon?
    If so, that definitely suggests a Windows networking issue.
    My first guess is that you may need to tell Windows that you are on a "private network".
    • Network and Internet settings
    • Network Status
    • Change Connection Properties
    • Network Profile
    • Private
