Isisunit
Apr 05, 2021Aspirant
A7000 Not Connecting to Internet
I’ve seen several other posts about this but no fixes that have worked for me. I have been using my A7000 with no issues with the Xfinity XB6-A modem/gateway since Nov 2020. I recently got a new XB7-T...
Isisunit
Apr 08, 2021Aspirant
It does not get an assigned IP address, nor can I ping from that computer. Also, if I try connecting the PC all my other devices get kicked off the network.
michaelkenward
Apr 09, 2021Guru - Experienced User
Could it be a Windows thing? Have you running the Network Troubleshooter?
By changing your network infrastructure, you have changed the network as far as Windows is concerned.
In your shoes, as this is an important work machine I would investigate the use of Powerline Ethernet instead of wifi. That turns the mains circuit into an Eternet network. If the mains circuit is up to it, Powerline is easier to set up and less prone to interference.
