Isisunit
Apr 05, 2021Aspirant
A7000 Not Connecting to Internet
I’ve seen several other posts about this but no fixes that have worked for me. I have been using my A7000 with no issues with the Xfinity XB6-A modem/gateway since Nov 2020. I recently got a new XB7-T...
Isisunit
Apr 09, 2021Aspirant
Thank you for the suggestion. The only change was the Xfinity gateway modem. My Windows 10 works just fine on the older modem (XB6-A), which I have reverted to. The office is only one room away from the modem with a single wall between the two - a distance of maybe 10 feet, so I shouldn’t need a booster. I’d switch to an Ethernet cable but the place I just moved to is not hardwired for Ethernet, and I’d prefer not to have to mess with wiring here.
michaelkenward
Apr 09, 2021Guru - Experienced User
Isisunit wrote:
Thank you for the suggestion. The only change was the Xfinity gateway modem. My Windows 10 works just fine on the older modem (XB6-A)...
You have changed your network. Windows expects to see the old one. I repeat. Check Windows.
- Blanca_OApr 13, 2021NETGEAR Employee Retired
Hi Isisunit
We’d greatly appreciate hearing your feedback letting us know if the information michaelkenward provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team- IsisunitMay 11, 2021AspirantActually I gave up and reverted back to my old modem/router from Xfinity. I’ll switch to the updated version once I’m back in the office vs remote.
- michaelwhitneyMay 10, 2021Aspirant
I am having the exact same issue. I have been all over windows. I am not sure what exactly to check. I have tried to forget the connection. I uninstalled and reinstalled the driver. I did try the network trouble shooter. Those did not work. Is there something else that should be checked or changed in Windows?
- michaelkenwardMay 11, 2021Guru - Experienced User
Possibly, possibly not.
Without a detailed description of what is happening at your end, what you have tried and what happened, it is impossible to tell you where to look for solutions to whatever problems you may have.
It is usually best to start your own conversation.The paid admins will have moved on to new conversations, especially when the person who started this one has disappeared without answering important questions.
