Tom444
Nov 16, 2019Apprentice
A7000 ongoing support or EOL?
Is the A7000 going to have ongoing support or is it EOL with all these issues under Windows 10? Constantly loosing connection, over and over. I've been through the whole disable Run Switching...
michaelkenward
Nov 18, 2019Guru - Experienced User
At two years old, the A7000 is nowhere near EOL.
The latest drivers may be a year old, but they should work until Microsoft does something to break the device.
What tells you that the A7000 is the cause of your issues?
Tom444
Dec 13, 2019Apprentice
Google the A7000 and issues.
Lots of people having the same issues as me.
Even here on the Forums people are having the same issues.
So what makes you think it is not an issue with the drivers?
There is NO Support for this device from Netgear, all the various thing you can try to resolve the issues have come from end users.
What Gives?
