Purge_Camo
May 29, 2019Follower
A7000 recent random disconnect.
Recently my Adapter for my pc has been random disconnecting from the wifi without blinking the blue light like it usually would if it cant find the wifi. so the past few days it has randomly been dis...
tommy_b
Jun 01, 2019Aspirant
I'm having a similar (if not the exact same) issue. I bought the adapter a week ago and it worked perfectly fine for the first 5 days. A couple days ago the adapter randomly switching between a full strength connection similar to what it used to be like and a completely empty strength connection that is unusable. I agree it is extremely frustrating as it interupts the flow of any computer activity involving the internet.
- Blanca_OJun 06, 2019NETGEAR Employee Retired
- Cheezus21Oct 21, 2019Initiate
i have this same problem, can you make the solution more public instead of email?
- kernelhappyJan 05, 2020Initiate
I can't imagine why they would PM the solution because I'm having a similar issue.
My adapter will go into a weird state where it will say connected without internet or the network will disappear completely and the only way to reconnect is to go into settings and turn wifi off then on. Other computers and devices have no problem staying connected.
Last night I noticed the blue LED blinks 9 time when the connection goes away.
This is a serious reliability and availability problem.
