brochosinco
May 03, 2020Follower
A7000 runs at usb 2.0 speeds when connected to usb 3.0
My A7000 wifi adapter is plugged into a USB 3.1 port but runs at USB 2.0 speeds. I have a program called usb device tree viewer and it shows the adapter only being on USB 2.0. I've tried all the USB ...
Blanca_O
May 11, 2020NETGEAR Employee Retired
Hi brochosinco
Welcome to NETGEAR Community!
Is the A7000 WiFi adapter plugged into the USB 3.0 magnetic cradle that came with the package?
Is there any difference if it is connected or not connected to the cradle?
Blanca
Community Team
n64robert
May 23, 2020Aspirant
I am also having the same problem, it makes no difference if i use the cradle or not.
3700X
MSI MPG-X570-GAMING-EDGE-WIFI
48GB 3600 Ram
Speeds are hard capped to USB 2.0 speeds. Could some please help?
