Birdies
Dec 27, 2022Aspirant
A7000 Software not compatible with MacBook
I'm trying to load the software for the A7000 adapter and it crashes on the MacBook Pro. Is there a fix for this?
michaelkenward
Dec 28, 2022Guru - Experienced User
You mean the installer crashes?
The bad news is that Netgear seems to be a version or two behind the versions of MacOS.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Adapters - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- BirdiesDec 28, 2022Aspirant
Yes, the installer crashes at the last few seconds of the install. Tried everything on the website, which is pretty lacking in any real solutions, and have a call into tech support. Thanks.
- plemansDec 28, 2022Guru - Experienced User
Not sure how much movement you'll see as this has been going on for a while.
Macs change quite a bit between versions and it breaks compatibility. Makes it a challenge to keep install drivers updated.
- BirdiesJan 04, 2023AspirantTech support told me if your computer already has Wi-Fi regardless of its age or type the netgear adapter will not work. This is for macs and pc’s. Seems odd.
