Birdies
Dec 27, 2022Aspirant
A7000 Software not compatible with MacBook
I'm trying to load the software for the A7000 adapter and it crashes on the MacBook Pro. Is there a fix for this?
Birdies
Dec 28, 2022Aspirant
Yes, the installer crashes at the last few seconds of the install. Tried everything on the website, which is pretty lacking in any real solutions, and have a call into tech support. Thanks.
Dec 28, 2022Guru - Experienced User
Not sure how much movement you'll see as this has been going on for a while.
Macs change quite a bit between versions and it breaks compatibility. Makes it a challenge to keep install drivers updated.
- BirdiesJan 04, 2023AspirantTech support told me if your computer already has Wi-Fi regardless of its age or type the netgear adapter will not work. This is for macs and pc’s. Seems odd.
