Mmbooger
Jun 20, 2026Aspirant
A7000 stops working with SVM mode
I'm on Windows 11 pro. I'm trying to enable SVM mode on my BIOS so I can run docker, but when I reboot after enabling it, the wifi no longer works. Even in windows' settings, when I click 'networ...
CrimpOn
Jun 20, 2026Guru - Experienced User
Hmmm. Internet search for running Docker on Windows 11 does not mention BIOS:
- StephenBJun 20, 2026Guru - Experienced User
It's an AMD setting ("secure virtual machine"). It's not needed for Docker, but I believe it is needed for WSL2.
Mmbooger wrote:
I'm trying to enable SVM mode on my BIOS so I can run docker, but when I reboot after enabling it, the wifi no longer works. Even in windows' settings, when I click 'network and internet' the settings window turns red and crashes
Is this happening when the A7000 is removed from the PC?
- MmboogerJun 22, 2026Aspirant
When I remove the A7000, it still continues to have the network and internet setting page turns red and crashes.
- StephenBJun 22, 2026Guru - Experienced User
So perhaps nothing to do with the A7000?
