Mmbooger
Jun 20, 2026Aspirant
A7000 stops working with SVM mode
I'm on Windows 11 pro. I'm trying to enable SVM mode on my BIOS so I can run docker, but when I reboot after enabling it, the wifi no longer works. Even in windows' settings, when I click 'networ...
CrimpOn
Jun 20, 2026Guru - Experienced User
It might be worth considering getting a WiFi adapter that is certified to be compatible with Windows 11 Pro. The A7000 firmware was last updated in 2018 and shows compatibility with Windows 7/8/10.
