Mmbooger
Jun 20, 2026Aspirant
A7000 stops working with SVM mode
I'm on Windows 11 pro. I'm trying to enable SVM mode on my BIOS so I can run docker, but when I reboot after enabling it, the wifi no longer works. Even in windows' settings, when I click 'networ...
Mmbooger
Jun 23, 2026Aspirant
Another update, I enabled SVM mode and booted and left for a little bit, then came back and the wifi was now working.
I'm going to try to install Docker again in a little bit and see if that breaks again.
thanks for your help everyone even though the issue doesn't seem to be due to the netgear item
- StephenBJun 23, 2026Guru - Experienced User
great news! thx for following up.
