Apota4U
Apr 29, 2019Tutor
A7000 USB Adaptor Constantly Disconects.
I have a A7000 USB 3.0 Wifi adapter that worked fine for a couple of weeks and now it constantly disconnects and to get it to reconnect I have to unplug it from the USB port on the back of my compute...
Apr 30, 2019Guru - Experienced User
Have you tried moving the adapter to a different usb port? maybe there's a bad usb port
The other thing I'd try is moving the adapter to a different computer to isolate it to the adapter or the computer.
Apota4U
Apr 30, 2019Tutor
I read on another post that their is some kind of issue people where having with a USB driver on Windows 10 that was making their wifi adapter disconecting and then connecting again, but I can't find the post again and I'm not sure what the solution was.
