Apota4U
Apr 29, 2019Tutor
A7000 USB Adaptor Constantly Disconects.
I have a A7000 USB 3.0 Wifi adapter that worked fine for a couple of weeks and now it constantly disconnects and to get it to reconnect I have to unplug it from the USB port on the back of my compute...
Apr 30, 2019Guru - Experienced User
Have you tried moving the adapter to a different usb port? maybe there's a bad usb port
The other thing I'd try is moving the adapter to a different computer to isolate it to the adapter or the computer.
Apota4U
Apr 30, 2019Tutor
I found the post here but I'm not sure if my issue is the same one.
I am having the same problem. This odd adapter is coupled with Netgear's R7000P (AC2300) router. To disable "RunSwUSB", double click the offending service and you will have the option to permanately disable the service. Simply select "Disabled" as the Startup type.
Model: A7000|NIGHTHAWK AC1900 WIFI USB Adapter
Message 7 of 9
