X0964364
May 09, 2018Tutor
A7000 USB Adaptor disconects and reconects
I have two A7000 USB network adaptors that are experiencing the same issue. They will randomly disconnect FROM THE PC. Not the network or Wi-Fi signal. It is as if I disconnected the USB cable. Drive...
- May 31, 2018
I am having the same problem. This odd adapter is coupled with Netgear's R7000P (AC2300) router. To disable "RunSwUSB", double click the offending service and you will have the option to permanately disable the service. Simply select "Disabled" as the Startup type.
michaelkenward
May 10, 2018Guru - Experienced User
Windows handles that. And your version is?
X0964364
May 10, 2018Tutor
Sorry, I should have included that info.
Windows 10 Home version.
This is true for both computers that are experiencing this issue.
