idobsyn
Jul 15, 2022Aspirant
A7000 USB Adaptor Gets Lower Than Expected UL and DL MBPS in 5GHZ Range
According to the product description "This AC1900 USB 3.0 adapter wirelessly connects your laptop or desktop computer with WiFi speeds up to 1.9Gbps." However, after increasing my Hyperoptic broadban...
- Jul 18, 2022
idobsyn wrote:
Based on what you've said, it seems clear you feel the issue is separate to the adaptor itself as other users can pull much higher numbers on this device.
Not really. I am just suggesting that networks are complicated issues and that it can take some effort to track down issues. And, of course, you have to cut through the fig of marketing when it comes to talk of speeds.
A good way to test a USB adapter is to try it in different devices and on different wifi sources.
Of course, if you have real problems with speeds on your network, the obvious answer is to replace wifi with a wired connection. Something like Powerline Ethernet might be an improvement.
idobsyn
I should say that I ran through the troubleshooting guide here: https://kb.netgear.com/24903/NETGEAR-USB-wireless-adapter-is-not-achieving-desired-speed-or-range
Adjust the location of the adapter relative to the router.
My phone hits much higher numbers from the same position.
Use a NETGEAR wireless extender.
N/A given how close the router is and that it's LOS.
Check for the latest updates and drivers.
The latest driver seems to be the one from 2017 (25/12/2017) and that's what's installed.
Check the wireless security encryption of your router.
WPA2 and again...the phone.
Get rid of obstacles.
N/A.
Use Windows to increase the power that is being sent to your wireless adapter.
I don't have a Transmit Power option.
Adjust the adapter with a USB extension.
N/A
michaelkenward
Jul 16, 2022Guru - Experienced User
- idobsynJul 16, 2022Aspirant
Yeah, I did see that but I believe my issue is different. While I appreciate that the numbers won't be as high as 750mbps, I'm seeing way lower than this using the A7000 when my phone in the same position is seeing much higher (see attached).
- michaelkenwardJul 16, 2022Guru - Experienced User
The speeds you quote are pretty good for many setups. Is the speed getting in the way of things that you do, or are you just looking at the numbers?
These things also depend on the USB drivers on the PC that hosts the adapter.
It isn't just the adapter's drivers that matter, but also those for the motherboard and its USB support. It isn't always easy to track those down. They depend on the particular chipsets that the PC makers used.
- idobsynJul 17, 2022Aspirant
Thanks for your thoughts and suggestions, Michael.
I'm really looking at the numbers because when I pay for a specific level of service, I expect to be able to get that (or in the case of broadband, something which is as close to it as possible given my system's configuration).
Regards your driver comments, I've tried to update USB drivers but I always seem to get the stock message that they're at the latest level so I'm at a bit of a dead end there, I think. And without really digging into the chipsets and the like, I'm not confident I'll ever get to the bottom of this issue.
Based on what you've said, it seems clear you feel the issue is separate to the adaptor itself as other users can pull much higher numbers on this device. As I've alluded to above, I think I'll end up down the rabbit-hole trying to solve this so I'm just going to give up and go back to 250mbps.Many thanks.
