stricknook101's avatar
Dec 24, 2022
a7000 usb dual channel looks alot like this d link thing
so  it seems to me that this d-link thing being pushed by meta looks an awful lot like my a7000 sub dual channel extender.
is there a way to decicate it to a single device? that device being my quest 2.
i dont understand the properties menu and dont want to just start hitting tabs
  • schumaku's avatar
    schumaku
    The A7000 https://www.netgear.com/support/product/A7000.aspx is a AC1900 wireless client to for one device connected from a USB port, allowing to establish a wireless connection to a wireless access point. confused because it claims to be dual-band? It's like your old AM and FM radio where you can listen to one program at a time only 8-)
    • stricknook101's avatar
      stricknook101
      Umm, yes i do understand that concept, not. For instance like i thought plugging a laptop 6 into a 5 combo unit would make it a wifi 6.
      The purpose of the question was, most of the things that matter is pushing for their product line happen to be existing products just much much more expensive so I wanted to check to see if the thing that I already have was going to replace what they're trying to sell me to use. I understand how it works I just don't know if I could get into it to dedicate it to one thing only which is the selling point of the D-Link on meta is that it's essentially the same piece of technology for only one piece of equipment major points for managing to use AM/FM radio in a responsible Wi-Fi question gold star
      • schumaku's avatar
        schumaku
        Not convinced i understand your question here or how to help you out from the confusion.
        Loool, sorry. If these 5 port unit has Ethernet switch ports, adding a 6 might be difficult. WiFi 6 is a wireless technology (802.11ax) available on 2.4 and 5 GHz band, and extended by adding more channels on the 6 GHz band to make up WiFi 6E. not sure what we should talk about here.
        The purpose of the question was, most of the things that matter is pushing for their product line happen to be existing products just much much more expensive so I wanted to check to see if the thing that I already have was going to replace what they're trying to sell me to use. I understand how it works I just don't know if I could get into it to dedicate it to one thing only which is the selling point of the D-Link on meta is that it's essentially the same piece of technology for only one piece of equipment ...
        Not sure i understand your question here or how to help you out from the confusion. nobody does try to sell you here.
        The subject you had chosen is "Re: a7000 usb dual channel looks alot like this d link thing" - so you want to have this A7000 wireless client operating on some existing wireless, or shall we talk about some marketing push from another brand on social media (especially when considering
