MoistT
Jun 01, 2020Follower
A7000 USB Wifi Adapter Intermittently Disconnects Then Reconnects
Hello, I've had an issue with my A7000 WiFi USB 3.0 Adapter since I bought it nearly 6 months ago. The WiFi adapter randomly loses connection and reconnects about 3-5 seconds later. It doesn't requir...
CaRoJin
Jun 13, 2020Aspirant
I have the exact same problem, to a tee. I have searched for answers on and off for months, to no avail. Absolutely nothing works, and unless someone responds to this post with an answer that works, I am just biting the bullet, and saving up for a new NON-NETGEAR router, despite the small fortune I spent on this one. Honestly, for anyone else who comes to this forum looking for an answer- here's my suggestion: if you have the money, buy a new router. This is a widespread problem that has lasted for years and there is no answer anywhere. Netgear doesn't care, so throw it in the trash and buy from a better company if they don't respond to this forum with a real answer that isn't "update software, check drivers, restart PC" like we are in kindergarten.
