Dubu
Nov 17, 2024Aspirant
A7000 Usb3.0 Adaptor wifi ping spikes
I had this wifi adapter for a while and I managed to fix this issue a long time ago but all of the sudden my wifi adapter stopped working as efficiently as before. I used to be able to run discord pe...
- Nov 27, 2024I gave up and decided to just buy a new product and now my wifi works again...
Dubu
It says "Update for Microsoft Windows (KB5045935) on 11/15/2024" theres also a security update one that says (KB5046633) same date
nathan0w
Ok so I uninstalled KB5046613 and restarted, it showed no change.
I did however follow the instructions and download the file from this page:
https://kb.netgear.com/000055980/A7000-Software-Version-1-0-0-15-Windows?article=000055980
(http://www.downloads.netgear.com/files/GDC/A7000/A7000_V1.0.0.15_Windows.zip)
After I downloaded and extracted the file, I decided to uninstall the device and remove drivers in device manager so it could not recognise the device anymore.
Then I unplugged the A7000, waited about 30 seconds, replugged it in, and then ran the standalone file from the download which re-installed drivers for it.
I've been using pingplotterr to monitor performance.
The red bar is when I uninstalled, removed and reinstalled device.
The left side is the ping/latency when I had issues (you can see it hitting high 1000ms)
The right side is after reinstall (ignore the 2 red ping spikes, that was me changing another setting so expected).
So it looks to have fixed it for now? I'll keep an eye out.
- nathan0wNov 17, 2024Aspirant
After letting it run a couple more minutes, the performance looks to be stabilised again, staying below 10ms. Performance attached below. Hope this helps you!
I also found the issues when gaming and using discord.I'll monitor it further tomorrow and update here if anything happens. Let me know how it goes for you?
- DubuNov 17, 2024Aspirant
Thank you that sounds like good news ill try out your method when I come home from work and update this post the next day
- nathan0wNov 18, 2024Aspirant
Next day update, all looks to be well. Ping/Latency under 10ms with a random spike now and again which i'm attributing to my own router issue but looks to have fixed the other issue. Will try a game later with discord and update!
