Dubu
Nov 17, 2024Aspirant
A7000 Usb3.0 Adaptor wifi ping spikes
I had this wifi adapter for a while and I managed to fix this issue a long time ago but all of the sudden my wifi adapter stopped working as efficiently as before. I used to be able to run discord pe...
- Nov 27, 2024I gave up and decided to just buy a new product and now my wifi works again...
nathan0w
Nov 18, 2024Aspirant
Next day update, all looks to be well. Ping/Latency under 10ms with a random spike now and again which i'm attributing to my own router issue but looks to have fixed the other issue. Will try a game later with discord and update!
Dubu
Im still having the same issues I noticed my wifi completely turns off or it says connected but no internet when I stream on discord. I also notice it spiked really hard after a couple of minutes.
- nathan0wNov 19, 2024Aspirant
I have had issues previously I noticed when I game, but not when I'm just browsing that showed a spike every minute or so. Apparently it was the device disconnecting from the wifi to try to find a better connection or something, but it is driven by a windows setting.
Maybe try, in CMD:
netsh wlan set autoconfig enabled=no interface="WiFi"
to turn it back on (make sure to turn it back on when you are finished otherwise when you restart PC, it won't find any networks!) use the below command
netsh wlan set autoconfig enabled=yes interface="WiFi"
where "WiFi" is the name of your network adapter.
If you're not too sure, just google the command to validate what i'm mentioning, a lot of gamers notice because of the spikes, I noticed because of CSGO 🙂
- DubuNov 23, 2024AspirantI tried running the cmd u mentioned and it says I don't have it? Not sure what that means
