SoonerVeebs
Mar 16, 2023Follower
A7000 WiFi USB Adapter Firmware Upgrade and Genie
I'm trying to use the Genie to check and possibly upgrade the firmware on my AC1900/A7000 WiFi USB Adapter. I have the latest version of the genie, and when I hit "check for update" it gets to 20% ev...
Mar 16, 2023Guru - Experienced User
You can download it directly from netgear and install it from there.
https://www.netgear.com/support/product/A7000.aspx
