bwelshon
Dec 02, 2019Aspirant
A7000 Wireless USB Adapter jumping from 1300Mbps to 54Mbps repeatedly
Hello, I wanted to advise of an issue I am seeing with my new A7000 adapter installed just yesterday. I have searched online for any answers, and have seen that many others have had the same i...
bwelshon
Dec 03, 2019Aspirant
Update on Dec 3
I did the netsh wlan set autoconfig enabled=no again on my WiFi network name tonight. This time I see that the ping issues I was getting earlier have been resolved. I must have mistyped something when I did this earlier.
It's a pain that you have to do this at all, but very happy it's fixed and I will be keeping this adapter now.
- bwelshonDec 04, 2019Aspirant
Another update:
What I also experienced is that when I shut my computer down and turned it on the next morning I was no longer connected to any Wifi networks. And, no Wifi networks were visible to connect to because of the netsh autoconfig enabled=no command that I had entered the night before.
Therefore, I had to issue this command again with enabled=yes to show wireless networks, connect to the one I wanted, and then set enabled=no again to solve the ping issue.
A pain, but it works. I will setup some batch files to do this or configure it in Local Security Policy.
