jfrancoisricard
Apr 30, 2023Tutor
A7000 with the wrong region
Hi! I purchased a netgear a7000 from best buy canada (I am from canada). In the netgear genie program, I see the region as EUROPE. This is causing me a lot of issues. I cannot see my 5ghz wif...
jfrancoisricard
May 01, 2023Tutor
Well thats weird.
The box states a7000-10000s, but I can't find any info on the unit itself.
The 'genie software' is the software downloaded from netgear. I searched for a7000 and downloaded the software for windows 10 there.
Thank you for your help
May 01, 2023Guru - Experienced User
I don't have that adapter so unsure but can you go into your device manager and change the region through there?
- michaelkenwardMay 01, 2023Guru - Experienced User
I went and looked for that option.
Windows >> USB devices
Couldn't see anything. Maybe I was looking in the wrong place.
- plemansMay 01, 2023Guru - Experienced User
michaelkenward does it show in the device manager under network adapters?
Good call. It is there, but no region settings.
Maybe it is buried on one of the other settings.
I also looked in Windows networking.
I still think it worth looking in the router (source) end. That is where I set my 5 GHz channel.
