jfrancoisricard
Apr 30, 2023Tutor
A7000 with the wrong region
Hi! I purchased a netgear a7000 from best buy canada (I am from canada). In the netgear genie program, I see the region as EUROPE. This is causing me a lot of issues. I cannot see my 5ghz wif...
michaelkenward
May 01, 2023Guru - Experienced User
plemans wrote:
I don't have that adapter so unsure but can you go into your device manager and change the region through there?
I went and looked for that option.
Windows >> USB devices
Couldn't see anything. Maybe I was looking in the wrong place.
michaelkenward does it show in the device manager under network adapters?
- michaelkenwardMay 01, 2023Guru - Experienced User
Good call. It is there, but no region settings.
Maybe it is buried on one of the other settings.
I also looked in Windows networking.
I still think it worth looking in the router (source) end. That is where I set my 5 GHz channel.
