journey001
Nov 28, 2020Follower
A7000/Nighthawk AC1900 reception speed 54Mbps only
Hello I have just installed the adapter on usb3.0 ports and connected to my wifi router (802.11AC, wpa2-personal) I used the last driver v1.0.0.15 from netgear site. But when I run cm...
Blanca_O
Mar 07, 2021NETGEAR Employee Retired
Hi journey001,
Welcome to NETGEAR Community!
If you are still experiencing issue using the WiFi adapter, kindly install lower driver version. Here's the reference link:
https://kb.netgear.com/000045297/A7000-Software-Version-1-0-0-11
Blanca
Community Team
