Waahmbo
Jan 05, 2023Star
a8000 and macos
Is there any particular reason that the a8000 (axe 3000 usb wifi adapter) is listed as not compatible with macos? I've never ran into an uncompatable wifi adapter yet.
Jan 05, 2023Guru - Experienced User
Probably because even the A7000 isn't compatible with the latest versions of mac? Its a couple generations behind on that.
Could be how apple is handling drivers/compatibility.
- WaahmboJan 05, 2023Star
You're probably right. Apple tends to hide everything from developers until the last minutes before an os release.
