DebiMarie
Mar 09, 2024Initiate
A8000 Firmware.
I am wondering which of the two updates on the A8000 page is the most current? I have the 1.0.0.108 installed and this one 1.0.0.125, wasn't available during my last visit checking for updates. ...
- Mar 10, 2024
I usually reckon that the one at the top of the list is the latest.
A8000 Software Version 1.0.0.125 (Windows) - NETGEAR Support
That one came out on 03/08/2024 which, when converted into real-world dates, amounts to 08/03/2024, or the 8th of March, just two days ago. Well spotted.
Another clue is that 125 comes after 108.
michaelkenward
Mar 10, 2024Guru - Experienced User
- DebiMarieMar 10, 2024Initiate
I would like to thank you for confirming my question and responding so quickly. I had a thought that I may be correct, however, I wanted to hear from others regarding this new update. I initially tried to install it but it said it was for an A7000 or something, and I deleted it. Never desire to whack up a device by downloading incorrect firmware.... Learned that lesson the hard way.
I have installed this new update and I can't seem to discover anything new. I am unable to get the 6e side up and running, when I logon to the 6G side of my router, my speed is only 866. I have the TP Link Archer AX6000 Router which handles Wi-Fi 6 and I haven't quite cracked it to allow at least 1201 speed or better. I shall continue until I do make this function properly.
- michaelkenwardMar 10, 2024Guru - Experienced User
You are right to be cautious, but in this case the update is not firmware but drivers and, if you install it, software on your PC.
Routers usually tell you not so be silly if you try to throw the wrong firmware at them. But stuff happens.
WiFi 6 is not 6 GHz if that is what you mean by 6G. That is 6E. (Why do they set out to confuse us like this?)
The links I followed to check on the AX6000 suggest that it isn't a 6E device.
I find that the only way to work out which band I connect to is by looking at Windows and what it claims the connection is. I don't have portable stuff that does 6GHz.
As to claims of wifi speeds, that's mostly snake oil.
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
