ghostlytraveler
Aug 09, 2023Aspirant
A8000 makes PC lag
Things I've tried: Reinstalling driver Disabled built-in Intel adapter Disabled auto-config through command prompt Disabled turning off adapter setting in both adapter settings in Network set...
michaelkenward
Aug 10, 2023Guru - Experienced User
While it helps to have a list of things you've tried, I can't see what the problem is beyond your subject, which is a bit thin on details for diagnosing what might be happening.
- ghostlytravelerAug 10, 2023Aspirant
The CPU, disk usage, and memory usage spike. The computer is very slow in all programs, including programs that don't use the internet, like file explorer. It lags when typing and scrolling in both programs that use the internet and ones that don't use the internet and sometimes when moving the cursor as well. Programs that use the internet, like browsers, are so slow that the net effect is that they're slower than without the adapter.
